Home Cinema Speaker Package - £1,600 Budget
Want to get a total new Home Cinema and am first looking at the speakers.
Was considering the B&W 684 or B&W 685's. However, these seem to be hard to come by, on the Internet anyway.
To combine with a Yamaha DSP-AX863SE AV amplifier, not included in the budget.
However, there might be better speaker packages out there for a £1,600 speaker budget.
This will of course be used for watching films in great quality sound (where possible
Thanks for the advice.
James
Great combo and can be found in some Sevenoaks stores for £1599 worth trying your local store another good deal is the Onkyo 606 and kef 3005se price £1099 seems a great offer.
I really wish you could B&W online.
Thanks for the two posts.
Any more recommendations?
JamesU2002:
Are you UK based?ÿ
Yes.
Its the only reason I am considering other makes, because you can't buy them online.
http://www.hifigear.co.uk/site/scripts/product_browse.php?product_id=4539
You can get the 685 Theatre Package there
Is it absolutely necessary to buy online? Give a few shops a ring, play them off against each other and then ask them to post the speakers to you.
Its just from preference, I feel safer ordering online from a reputable company rather than giving details over the phone.
I may still order the B&W via phone but are there any more options?
So alternatives to the B&W around the same price/quailty?
