Home Cinema for (absolute) beginners
Receiver has a radio built in, multichannel amp doesn't.
There are also multichannel power amps, which have to be used with an external surround sound decoder/processor.
Andrew Everard:
So to make your TV sound good, you buy a radio....?
Andrew Everard: There are also multichannel power amps, which have to be used with an external surround sound decoder/processor.
On a slightly more serious note, the Sony BDPS550 has multichannel out. Does this obviate the need for the decoder/processor?
A receiver/multichannel amp will have several inputs, making it more versatile. If you just used a power amp, it would only have one input so wouldn't be able to be used with anything else, unless you unplugged the blu-ray and plugged in somthing else. I'm not sure if a power amp would have a volume control either, that would be down to the processor.
