HELP! Speaker cable fitting......
I've just bought some new CM7's and really want to listen to them.
Unfortunately, I have terminated speaker cables and the CM7's don't seem to have the right plug for these. I'm assuming I'm being really stupid and there's something I need to do...can someone tell me what that is please????
What does the termination on your cables look like? Unless it's something very exotic I'd be surprised if the CM7's can't accommodate the connection...
Oh, If you've got banana plugs you can remove the little plastic caps covering the terminals on the back of the speakers. The plugs should just go in.
Also, banana plugs usually fit through the hole in the binding posts of speakers, where bare cable is supposed to go. Just be careful not to tighten too much or you will damage the banana plug.
