Help Please, Urgent.
Basically, ive just hooked up my Denon UD-M50, great little system, ive hooked it up into my Samsung (Series 5 i think, with a hint of red in it), i also have sky +. I was wondering if it is possible to control the volume on my Denon UD-M50 system by using the volume control on my Sky+ remote.
All help is appreciated, cheers
Well, the Sky remote codes for Denon are 0032 or 0188, with some sources suggesting 1388 may be an alternative, so it's worth a try.
Cheers Andrew, ive tried these but im not sure what order or what buttons to press in order to get this to work.
whichever, it gives you the punch-thru code so you don't have press the TV button to turn the amp's volume up and down, if that's what you want to do of course.
the_lhc:Talk to the hand, girlfriend...
No, you've lost me now. Is that a threat of violence to a female member of the forums...?
Andrew Everard:
Don't be silly, it's the anti-macho call to arms...
Jeez, you've never heard the expression "talk to the hand cos the face ain't listening"? It's about the least macho thing you can say so to have someone suggest i'm threatening violence by saying it IS silly.
the_lhc:you've never heard the expression "talk to the hand cos the face ain't listening"
No: what does it actually mean?
EDIT: Ah, I see, it is aggressive: 'It originated as a contemptuous way of saying that no one is listening, and is often elongated to a phrase such as "Talk to the hand, because the ear's not listening". Also, in regions south, "Talk to the hand because the face don't understand!"
'The sentence is often considered to be a sarcastic or obnoxious phrase. It is usually accompanied by the gesture of extending one arm toward the other person, with the palm of that hand facing the person being insulted, in the manner of the gesture to stop.'
In other words, you were suggesting I shut up. Thanks for that.
Andrew Everard:
No, actually, I wasn't. You said I was being macho, which I wasn't, I was simply repeating the phrase used in the link I posted, so I, in an attempt at humour (which seems a long way in the past now...) replied with about the campest, most un-macho phrase I could think of, to indicate that I am not and was not attempting to be macho.
If you choose to blow it out of all proportion by accusing me of things that I'm simply not doing then that's your problem, not mine.
the_lhc:replied with about the campest, most un-macho phrase I could think of
In which respect you clearly missed by a country mile...
Andrew Everard:
Only if you look at the origin of the phrase, if you look for the people who are most likely to say it now, you'll find I'm spot on (for example the last two times I heard it was from Graham Norton and on an episode of Will and Grace).
