- Dec 16, 2013
- 2
- 0
- 0
Hi all,
Long time lurker first time poster looking for some advice on my first "hi-fi" set-up.
I've currently got a fairly modest set-up and I'm looking to upgrade to some entry-level hi-fi gear. I have a Pro-Ject Essential TT with the stock Ortofon OM5e cartridge (http://www.project-audio.com/main.php?prod=essential), a Pro-Ject Phono Box (http://www.amazon.co.uk/dp/B000YEK1AQ), and Behringer MS16 speakers (http://www.amazon.co.uk/dp/B00181T20O).
I'm looking at replacing the speakers and buying an integrated amplifier. I haven't been to any demos yet as I'm still researching but, based on reviews I've read online, I'd defintely like to check out the following speakers: Q Acoustics 2020i, Wharfedale Diamond 121, Dali Zensor 3.
I like the look and spec of the Denon PMA720AE amplifier and would see it as an investment, but I wonder if it's really necessary for my listening environment - perhaps the 520 would suffice? I live in a one bedroom flat, the music room is 3 m / 3 m.
My budget is between £400-£500. I mostly listen to post-punk and new wave, along with some classic rock and contemporary dark electro. A strong kick drum, sparkly guitars, and clean vocal is important to me.
At the moment, the set-up will be used almost solely for playing vinyl but also for connecting my iPod occasionally (I'm aware the PMA720AE doesn't have a dedicated iPod input). This will be my first major foray into hi-fi construction so I was wondering if you experienced lot could suggest a few pointers?
Rob.
Rob.
