dalethorn said:That first link to Amazon with the £3.50 adapter looks right. Although I think the adapters are too short to introduce enough capacitance etc. to modify the sound, I have had a couple screw-on adapters supplied by Beyerdynamic and others which had loose connectivity when screwed down tight onto the 3.5 mm plugs.
drummerman said:I would have thought that the 'perfect' adapter is either silver/rhodium plated for better conductivity or at least be pure copper.
I had a quick look on Furutechs site, purveyors of all fancy connectors and couldnt find a headphone adapter which is a surprise considering their ADL line makes h/p amplifiers.
regards
MajorFubar said:I'm surprised there aren't 'audiophile' adaptors costing £30+ with some loon somewhere swearing they can tell the difference.
jjbomber said:MajorFubar said:I'm surprised there aren't 'audiophile' adaptors costing £30+ with some loon somewhere swearing they can tell the difference.
Or, even better, throw the headphones away and spend £1,300 on some active speakers!!!
OneBoxSystem said:MajorFubar said:I'm surprised there aren't 'audiophile' adaptors costing £30+ with some loon somewhere swearing they can tell the difference.
http://www.aloaudio.com/alo-audio-lariat-1-4-female-to-male-mini-adapter
There you go....
