Headphone amps
Nadeac
69
Which ones do forum uses recomend ? ,theres a lot out theres especially on Ebay from abroad ,prefferably £100 or under .Is there really much more difference between them and more expensive ones that warrant the extra money?
Thanks Mark
idc
1,142
117
19,370
The difference between a Musical Fidelity X-CANS, modified X-CANS and X-CANV8P is enough to justify a price range from £130 to £450. In the same way, if you are looking for improvements in sound quality a £130 amp will sound different from a £450 amp. The e-bay less than £100 headphone amps tend to be portable for use between ipod (or similar)and full sized headphone. I have not heard any but there are good reviews out there for the likes of the C-moy and Blue Jelly (second time today!). But what I am sure about, is that the more expensive amps will drive full sized headphones to their full potential. That is from connecting Grados and Sennheiser buds to a MF amp and an ipod. Horses for courses.
Nadeac
69
Ok thanks after looking around i will probably go for a Project headbox 2 to match up with my project Usb box .
Anybody got one ? what are they like ,Whathifi gives it 5 stars
Would be used with a pair of Audio technica ATH -Ad700 Anybody use that combo ?
Will i get a noticably difference compared to headphone out on my Nad amp?
Thanks again Mark
