HDMI
JoelSim
767
I have a 1.5m Chord HDMI and I'm happy with it. The problem is it's not long enough and ideally I would have a more flexible, longer cable so that I could hide it more. The missus has asked me to swap it for a black/brown cable that would blend into the wallpaper more, and by having a longer one, I could also move it so that not so much was showing.
Any recommendations?
I have exactly the same problem - The Wife!
The amount of equipment I have had to reject because it doesn`t fit in with the furniture / wallpaper!!!
She's happy enough with the rest of it, just the wires that are on show that are the problem.
ÿ
I had to buy an Alphason oak cabinet to put my equipment in and hide all the cables.
Have to admit that the cabinet is a quality piece of furniture and it does hide all the cables which are many!!
Plasticoat spray paint. Simple to apply and gives a very nice finish.
I need a longer cable and don't really want to shell out £200 as it's by far and away not the most important part of my AV system.
ÿ
Another solution would be to chase it into the wall. You wont see the cable at all then, and the wife gets to re-decorate.
