I'm looking for some advice on my setup as I'm having intermittent problems at the moment.
My amp/bluray/foxsat sit on one side of the fireplace with a 7.5m HDMI cable running under the floor to the Pioneer 4280 on the other.
I've short (50cm) cables connecting the Bluray and Foxsat to the Sony amp and then a "Ex-Pro Gold Professional - HDMI 1.3 Compliant - 7.5m" bought from amazon connected
from the amp output to the TV.
I've set the kit up a few times now (took it all apart and reconnected when i dropped the cable under the floor) and still find HDMI a bit of a mystery - it's not possible to 'force' HDMI on the amp or TV. ie you can set them to look for component or scart but HDMI is not in the menus.
The implication is that it should 'just work, which is great when it does....
However, each time i've connected the Foxsat it taken either a factory reset of the amp (the first time) or repeated power cycles of everything to get the Foxsat to connect and get a picture and sound.
After initial detection i'm still getting intermittent problems - last night we watched a few hours of programmes and it was fine but the night before the picture and sound were lost 3 times in a 30 minute show (in this case switching to and from the Foxsat input on the amp a few times got it back). The BluRay works fine however.
It seems i'm not the only one who finds the Foxsat HDMI flaky but I don't know how to address it. Humax's advice to connect directly to my screen isn't a lot of help.
Surely if my bluray working without (and 1080p will require more bandwidth than 1080i foxsat outputs) thought i could assume that long cable no problem so has anyone had, heard of, problems on sony 2400es with any other devices? how does switching work - is it just a passive switch (i d have assumed not since audio is processed by amp, although amp won t upscale or put graphics over the top of an hdmi input)?
