Harmany 525 remote
Do you meant that it changes to a different input, or does it cycle through to the original input?
In the TV setup menu, you may be able to skip unused inputs. I found it helped when setting up my 555. The simpler the setup the easier it is for the remote to control. Do this and Juzzie Wuzzie's advice and you should be sorted.
