Question Harman kardon citation 16 variable resistor
Badula
14
Hi all. I need some help.
I have recapped art Citation 16 amp. Unfortunately it suffers a common problems on these amps it seems. The variable resistors are finished.
Is there someone who knows what kind I should replace them with? A link perhaps?
I know the 500ohm one. But what does (IM ohm) mean?
Badula
14
Are you sure that one isn't 500k ohms (500,000 ohms)?
Do you mean variable resistors on the PCB (known as presets) rather than rotary controls (like volume/ tone controls?
The variable resistors on the PCB board. One is for the idle current. And the other for Output “idle”
As I can se in the service manual the is no K in the 500. I will attach a file
Gray
Any kind? Or any brand?
Provided that they're physically the same (the 3 pin / leg spacing / horizontal or vertical type).
Whatever types you're replacing, go for the enclosed, rather than the open (skeletal) types.
Search 'preset resistor' and you'll see a few.
Use an accurate meter to set them 👍
Badula
14
Thank you very much. As one replied and questioned 500ohms. Is this a correct value ? There is no K in the 500 ?
Badula
14
Yes, assuming the manual is correct, then VR2 is 500 ohms.
Hi again!
Problems… got the new variable resistors…
There is 30 volt!!! On channel A (blown transistor?!) 🤬 and Channel B “kinda works” but as hotter it gets on channel B the idle current lowers!?! Bad emitter resistors ?? It goes even to Minus ➖ as hotter it gets ? Ahh son of a *****… 😤😭
Badula
14
It seems also that the PA/UA739pc IC are spooky to… read on many threads that these Opamps are bad… any one out there who has knowledge about these ones?
Gray
Hi again!
Time to decide if / how much you're prepared to pay for a professional repair.
Get reliable estimate(s) first 👍
