- Sep 9, 2008
- 40
- 0
- 0
On a recent post someone mentioned using the product Green Glue as a cheap way of insulating a cinema room. I have an older house with sandstone wall and a cavity then lathe and plaster. I am well aware that the best way to sound proof is to build another stud wall and insulate the gap however this is not an option – size of room and cost.
Could I drill holes in the lathe and plaster and squeeze in the Green Glue to fill the cavity and therefore soundproof? Or would doing this cause dampness as air could no longer flow. How effective would using Green Glue in this way be?
I suppose it’s useful to use it also to fill cracks in old floorboards with Green Glue before putting down underlay and a carpet?
Advice appreciated.
Advice appreciated.
