great amp for under £300
henxuk
19
Hey there,
what amp should I get for £300  with a pana 42 plasma,  and  mission m cubes with ps3 blu ray
- i wanted an sony dgr 820 but they seem hard to get hold of, are there any new ones that are worth waiting for?
oh I need full hd sound and at least 3 hd inputs i guess,
any help would be really appreciated
cheers guys
A feature packed amp for under £300.00? You won't go wrong with the Onkyo TX-SR605. I've seen some re-furbished units going for £250.00 on E-Bay. It originally cost £400.00 not too long ago and is an award winner.
It will decode all of the HD Sound formats, but I think it has only 2 HDMI inputs and 1 HDMI output. This amp is certainly a step up from the Sony 820 or Yamaha 763, in my opinion.
Hi
Have to say Onkyo 605 is a fine bit of kit. I have never regreted buying mine.
I think with m cubes it will sound great.
ÿ
Bc.ÿ
I have the Onkyo 605 and I love it to bits. When I initially had the JAMO A102 HCS5, I had a listen to the Sony 820 and Yamaha 763. The Sony, I felt was too bright and the Yamaha just lacked the oompphh for me.
Then I got the Onkyo 605 (used, on E-bay) and have not looked back since. Great amp.
right then that was easy.
ÿ
Except does the 605 allow for hd sounds ÿetc
ÿ
It will be playing through a ps3 ÿ
ÿ
oh also whilst were on teh subject so i use PCM or the other transcode setting thing?ÿ
Will I regret not shelling out a bit more for say a 606 or such like with the added TrueHD or DDPÿ
features etc, ÿI suppose its all price the 506 = £194 ÿand the 606 = 379
ÿ
ÿ
oh also whats the sccop on this new onkyo 507 ÿ is this just an upgraded 506?
really you sure?
ÿ
http://www.richersounds.com/showproduct.php?cda=showproduct&pid=ONKY-TXSR506-SIL
ÿ
Dolby Digital Plus/dolby TruehdAre DDP or TrueHD included? Dolby Digital Plus is the next-generation, "better-than-DVD" sound processor and works up to 7.1 channels. TrueHD is Dolby's current ultimate system and has been designed specifically to get the full potential from HD-DVD and Blu-ray.ÿNo/NoDts High Res Audio/dts Master AudioAre DTS HRA or MA included? DTS-HD High Resolution Audio delivers sound even more accurate and consistent than standard DTS. It has been designed to extract the most from HD-DVD and Blu-ray. DTS-HD Master Audio takes this one step further and is capable of delivering audio that is bit-for-bit identical to the original.ÿNo/No
ÿ
awesome just got my self aÿOnkyo TX-SR605 ÿat the knock down price of £180
ÿ
gotta be worth it, hell I could get two for that price instead of a 606!ÿ
