I’m in the market for a good source for my set.
Currently I own a Marantz Pearl Lite with Kef R500 speakers, and i’m really happy with the sound.
At the time I needed to save a little more before buying a good source (currently I have an old Pioneer dvd player and an Eminent mediaplayer). The Pearl Lite SA player would be a good source, but I don’t listen to cd’s that much and own no SACS’s.
Ideally I would like a source to replace them both, 1 unit for playing cd’s, mp3’s, FLAC’s, and divx/mkv files, and if the unit can be used as a DAC it would be a big plus. But I can live with 2 units if that is the best solution.
I’ve been searching for some time know and I’m looking for some advice:
What I found so far is that there are two ways to go:
Buy a decent DAC/streamer and a universal player like the Panasonic DMP-BDT500
Buy a good universal player like the Cambridge Audio 752BD. (The Oppo 105 costs €1700 euro’s in my country which is too much, the UD7007 doesn’t play FLAC files from usb media, does not support NTFS disks so HQ mkv movies, > 4Gb will not be playable and doesn’t have a smartphone app.)
What can you recommend as a decent DAC to match my set? Will one like the Arcam rdac do justice the system?
Would it be better to have a separate DAC/Streamer (like the stream magic 6) for music and a UP for movies? The Marantz NA7004 is also an option but I’m afraid it will not get the best out of my system and the remote control app seems to be a bit of a joke.
The total budget is €1200.
Any advice will be welcome!
