- Feb 5, 2016
- 2
- 0
- 0
Hi there, I'm a bit confused by the volume produced by my amp. Here's my current setup: Turntable: Pro-ject Debut IIIDAC: Oppo 105-DAmp: Sony TA-FE370Speakers: Monitor Audio Silver RS1Active Speakers: Yamaha HS5 (for DAC only) Turning the volume knob on my amp to about 10 - 15 percent produces ample loudness with any record I play. I've never cranked it past 25 percent because it's just so loud - is this normal? The sound doesn't distort, it's just that at 15 percent it's at the limit of a comfortable level. The amp is in source direct mode and loudness is off. When I feed the same amp digital music (CD or files) via my DAC, the volume on the amp needs to be at least 50 percent to reach the same loudness. The turntable is connected to the PHONO RCS input on the amp. The DAC is connected to the CD RCA input. Confusingly, when I connect the DAC directly to a pair of active speakers (Yamaha HS5) via XLR, again the volume control on these speakers never goes past 10 or 15 percent because it's super loud above that. Am I doing anything wrong? Somehow it doesn't seem right for the required amplification to be so low. Am I getting the most out of the components and fidelity/detail from the sources? Is there a smarter way to get my levels right with this kit? cheers,Rafi
