- Aug 10, 2019
- 2,556
- 5
- 0
hi all,im not sure if its ok to do this on here but i notice a few posts on rooms,speaker placement,mains supplies etc and would like to recommend to you all somewhere to try,its a very easy to understand book by Jim Smith called GET BETTER SOUND,google it and check it out,i will tell you this,its the best money ive ever spent on hifi(i have nothing to gain from this by the way),the advice within this book would i suspect be of immense benefit to lots of you out there,it has helped me no end,the speaker set up tips are excellent,
