smuggs: thanks frank, so i should be looking to save up then, when you say better how in terms of pounds for example brand new in todays market. Just after a target to start the piggy bank. And if possible a few brands that would work well with the arcam aplha9 (genie2/dac-magic).
It depends what sort of sound you're after. To me, the BR5's are a little on the warm/bassy side, and are not the most refined as far as treble is concerned. Don't get me wrong, they're a reat speaker for the money, but compare those as representative of a £400/500 floorstander to an equivalently priced standmount like the Monitor Audio RX1. You get wood veneer (instead of vinyl wrap) wrapped around a more solidly braced cabinet, which produces less bass/midrange colouration. You also get smooth cabinet edges which make the speaker nicer on the eye. You get a higher quality bass driver (albeit one less) that is more responsive and accurate. The RX1's are still a little bassy as most MA's are, but they're capable of a more convincing, 'out of the box' performance. Something like Rega's RS1's will give you similar results too, and will sound a little more lively.
so is it that the alpha9 is just pushing the br5's to there limits and showing the weakness's alot more than say my old rotel rx202mk2 or denon1909 and in that way undoing the good points like easy to drive punchy upfront and deep bass for small cabinet.
The Alpha 9 won't be pushing the BR5's to their limits, it'll be helping you get the most from them. The RX202, although I'm not familiar with it, is more than likely still great sounding product, so I can't see them sounding bad on the end of it. The 1909 isn't going to test them - it's not a hi-fi product, and therefore will not get thbest from them.
