- Apr 25, 2014
- 3
- 0
- 0
I'm looking to buy a hifi system (my cheap "home cinema in a box" and P.C. speaker systems just don't cut it anymore) and I'm thinking of spending about £1000 - £2000 sometime in the next year (should be getting my first job soon, but living with parents means I'll still be getting at least half my pay check, so 3-5 months post job) I'm hoping to keep it for several years, even if it stops being my main system, which includes during moving. It can't be too sensative to positioning (so preffereably front firing ports) and will be for relatively small to medium sized rooms. I listen to a bit of everything, but mostly rock, metal, heavy metal and songs with bass. I try to keep flat serfaces to a minimum but it's not always possible so a flexible system is nessecary. The system doesn't need to be super high quality, I probably wouldn't be able to tell anyay :roll: Just clear and fairly loud, so if I can get that on the cheaper end, that'd be great. I don't mind about the size (I'll fit it in) and style is deffinately a secondary consideration to quality. Also (in the hopes you can get better quality for cheaper without this stuff) I don't need or want bluetooth or networking or any of that funky stuff. Just looking for suggestions to get excited about and demo when I have the cash, so cheers in advance for the suggestions :cheers:
