Exciting times, currently assembling my first ever AV setup!
Pikman
24
Went shopping this week after some help on here and now have a few boxes waiting to be unpacked (read, looking badly re-packed after I immediately opened them upon receipt!).
Just got my QA 2010's on the walls and tonight I hope to find a place to put the center (likely in front of the TV on the same stand temporarily) connect up the 2310 receiver and see how it sounds.
I ought to get something underneath the TV to lift it up a little so we don't have our view blocked as I am still trying to figure out how best to wall mount the AE V2 centre, just not sure yet...
Either way, it'll be fun 😀
Assuming that means photos and not some make I've never heard of, yes 🙂
Finally got it all together, didn't leave enough speaker length on a couple of runs to get the amp back out which is a little silly, needs more ordering. Still sounds OK though, at least it all works.
I also haven't got the centre on a mount yet, should get that Friday so by the eve I can kick off the proper setup and give it a good listen!
All done, no idea how to insert an image though, guess I need to link to Flickr?
I think the centre speaker might be too high, about a foot above the TV... doesn't quite sound like its coming from the front, but a little bit higher...
think you`re right `bout the centre speaker, a tad high but system looks good though
Cheers 🙂
Not really sure how that happened, I measured it all up to be spot on then must have started drilling at a totally different point!
It is better now I have angled it down more, plus I'm not allowed to move it anyway
