dynovector 10 x 5
evo6tme
31
Hi
Just had a thought . I`ve got my dynovector 10x5 conected to the moving coil conectors of my phono stage . But being a hight output moving coil should it be conected to the moving magnet ????
shooter
210
evo6tme:
Hi
No.
Yes. It's a high output MC, so should be connected to the MM input.
evo6tme
31
Yeh ok i know its sounds like a stupid question (grottyash), but it sounds ok in both , and i thought hight output mc were designed for that exast reason. I was just looking for a definative answer .
But then again i must remember were i am
jerry klinger
37
I've tried one into an MM and an MC stage, bit overloaded on the MC stage but quite listenable. Sounds fine into an MM stage.
evo6tme:
You are exactly right. I know people do sometimes use the MC input for high output phono stages, but you shouldn't, as it can cause distortion, particularly if you start ramping up the volume.
Generally, I wouldn't do it and stick with the MM input. It's true it may give you an imbalance in volume compared to other components such as CD, but the circuitry is designed for higher output, whereas that for MC is not.
ASK THE COMMUNITY
