Timpd said:So, just a warning really, don’t believe the hype, go out and audition for yourself. I thought I could not go wrong. It was lazy and has cost me dearly.
Any thoughts on the set up would be welcome.
Regards , Tim
Timpd said:This is for another time but what is the process / etiquette of auditoning? How many different combos can you try before the assistants start getting fed up? How long can you listen to your favourite tracks on each combo? Not being sure probably contributed to me not auditioning. I hate wasting other peoples' time.
Tim
the record spot said:I don't really buy that and I can see where the OP is coming from. Chebby pointed out the other day that the combinations you can run up to, purely in practicallity terms, makes listening to a wide range of gear a problem. Plus you have the issues of swapping gear around, all of which takes time.
For two CD players though, an hour's demo should be enough and you'd probably work it out in much less time. Most good dealers will let you have this time.
Timpd said:Brief history. Had a Rotel RA 01 with Rotel RCD 02 running B & W 601 S3s in the living room and a pair of Sonys in the kitchen .Quite happy, it was background music. Moved to a bigger house and that set up does not work so I started buying Hifi mags to fill in the gaps. Bought a Marantz PM 6004 on the strength of reviews and MA RX1s as they were going for the same price as BX2s. Very happy ,sounded great but I thought the CDs were not as punchy and incisive as I thought they could and should be so yesterday I bought the much heralded, best in class CD6004. And blow me; I cannot separate the Rotel from the Marantz. Either the Marantz has been overhyped or the Rotel is a lot better than it was given credit for.
Regards , Tim
Overdose said:the record spot said:I don't really buy that and I can see where the OP is coming from. Chebby pointed out the other day that the combinations you can run up to, purely in practicallity terms, makes listening to a wide range of gear a problem. Plus you have the issues of swapping gear around, all of which takes time.
A modicum of common sense should prevail. I didn't think that I'd need to add that though.
Timpd said:And no it was not bought on the internet. I went in a T audio
Regards , Tim
Timpd said:I am not blaming WHF. I have taken full responsibility for my actions . My only problem was not realising how good my Rotel gear was. It was about the cheapest gear n the shop so I assumed I could only go up the chain. The PM 6004 and RX1 are great I have no problem with them. I am sure I am not alone in not realising how good the sound is and looking with some envy as others buy £1000+ pieces of kit. If I stop reading WHF I am sure I would be happy with what I've got for another 10 years. I just got caught up with upgradidtis. The CD 6004 stays as the shop I bought it from is closing shortly anyway. It has better connectivity which may come in use one day.......
Thanks Tim
