- Aug 10, 2019
- 2,556
- 5
- 0
I'm planning on buying a Cambridge Audio 640A Amplifier, with some Wharfedale Diamond 9.1 speakers. I am going to play my itunes on my macbook pro through this hifi set up. To improve the sound quality I am going to buy the Beresford TC-7510 DAC for between the macbook and the 640A. However, I am unsure as to what the best set up would be - should I use an Airport express and stream my music to the DAC, or should I connect it with wires (which cables would I have to use for this). What would the difference in sound quality be? Obviously the airport express would be better based on that I could have my macbook anywhere in the room, and there would be less wires - but which would sound best, and would there be a huge difference between the two?
Also, please could you comment on the set up (amp and speakers - will this be a good match?; are there any other amps and speakers that are better (simular price range) and that would perhaps be better suited together? Do any of you have any experience with this set up?
Any help and advice would be greatly appreciated!!! 🙂
