digital connection
Am buying Arcam rDAC to hook up to Marantz amp and Kef iQ5 speakers. Need some advice on what type of cable to use between arcam and marantz. Thanks.
Not a digital connection but an analogue one - and based on your kit, I'd suggest the 2010 Award winner...
John
Would this be a good choice for the front pre out connections from my Yam 1065 to Nait5i amp?
Currently a QED something-or-other (about £20 I think) is doing the job...
I use to connect my amp analog cables made by Atlas 1meter voyager paid £80 quid and that was sale price if you really wanted to go to town you could buy the VAN Der Hull RCA 1 meter cable for £7,950 but I think that good quality cables are important analog ones that is but as for digital you could use cheepish ones.
Atlas and Chord are the ones I would recommend
