Hello,
I was hoping some people using the Denon DM37 micro system could check this out for me. I had two of these units, and both had to be returned as when using headphones (Sennheiser HD497) and taking the denon off 'source direct' mode (i.e. any change to treble or bass, up or down, or turning on the bass boost) would result in quite a lot of hiss through the headphones (think of a tape with no dolby NR)
I was wondering if this could have something to do with the sensitivity of the headphones? But surely there should be a hiss all the time, it shouldn't disappear in source direct mode? The headphones are completely silent on all other systems, decent amps (NAD C320bee, Rotel ra-01 etc etc). I think the hiss was also present through the speakers, but not really noticeable unless you were listening for it in a completely silent environment.
I also thought the denon was a little bass light, hence why i was trying to turn the bass up a little. I'm still tempted by it, but would like to figure out this problem first!
Any ideas as to what was going on?? I guess my only definitive answer would be to take the headphones along to a dealer and check out a display unit to see if the problem is still there. I suspect a design fault rather than both of the units i got being duff though.
