- Aug 10, 2019
- 2,556
- 5
- 0
Recently purchased (few months) the above amp and speaker package. Installed and one speaker buzzes and the sound is distorted through it. Speaker in question is a front speaker (FR). During the set-up this particular speaker showed as 'Caution - message' on the amp display and from this the manual advised:
1. Check polarity of wiring is correct
2. This message can be displayed even though there is no problem with certain speaker brands ?
The wiring has been checked at least 3 times and the whole system recalibrated following the prompt messages from the auto-set up on the amp. As you've probably guessed the speaker is still not working correctly, all the others in the system set-up ok and work fine apart from this odd one.
I have also tried changing the speakers around and still get the annoying buzzing.
Anyone who can shed some light on this would really be doing me a great service.
Cheers All
S
Cheers All
S
