Denon Avr 1400 h - no headphone output
Do those headphones work when plugged into anything else with a headphone socket?
I mean are you sure the headphones themselves are fine.
More likely you need to set the headphone output level manually, check the manual....
gianry
8
only one thing, I need to use an adaptor like this as my headphone have 3,5 mm jack :
Gray
I've measured the resistance on the two channel pins ; both headphones I own are 2,1k ohm .
If they work on your PC and i-pad, then clearly they would work on your Denon (if there is actually an output on its socket).
(By the way, recheck your measurements:
On your TRS plug, going from the pointed end you've got Tip, Ring and Sleeve.
Your 2 resistance probes go on tip and sleeve to measure left - and ring and sleeve to measure right driver - each a bit less than 2.1 k ohms now surely?)
gianry
8
You are right ; the resisteance of the mic is 2.1 k ohm . The resistance of the drivers is more less .
I ve used the headphone with adaptator on a c’è player and works .
Now I’m sure the denon has a defect
could it be only a connector failure
