Denon AVC-X3800H
barnsleydave
8
I think this may find a niche where one doesn't currently exist, as an affordable pre-processor.
The addition of dirax and 4 sub outputs, mean adding a power-amp or 2could well be a much cheaper option that what currently exists for those wanting to move to separates.
Its always frustrated me that the cheapest pre-processor is about £2500.
You could start with this device on its own.
Then you could contemplate a 3 ch power amp for front 3 speakers and use the on-board amps for the surrounds and atmos, until funds permit otherwise.
I think this could be a very good and welcome move.
kostas
Unfortunately, with the price for Dirac 4 sub control and required microphone you add another 750 pounds!!!! So, it's not a cheap pre-processor! Cant find a reason to upgrade someone from 3700 witch costs half price!
gardener88
I have the Q accoustics 3050i in 5.1 set up. Is Denon AVC x3800h a good match or are there better options?
i have an old yamaha rx v583 at the moment and i m not satisfied at all on the movies.
LasseG
Doesn't Pure Direct disable all audyssey corrections including Multieq? Doesn't really make sense to say that you've used Multieq to calibrate and then use Pure Direct..
