denon avc -10se
hi..this is my first post on this forum hope someone can help ..have changed the screen to hd and now have blue ray and vigin hd+ ..as the amp is the older type cant use hdmi for audio..i have connected the amp to blue ray with 6, cables audio out to audio in ..screen on amp shows 6.1 ext in ..problem is cant change the surround settings ie dolby suuound or home thx etc ,it did work with my previous much older system..guy from virgin suggests use optical cable for audio on their box..was thinking of getting a denon poa-t10 to get 7.1 at a later stage .thanks to anyone with some help.
Andrew Everard
1,878
On that amp the multichannel analogue in works as a pass-through - ie signal goes straight from the input via the volume control to the onboard power amp section, without going anywhere near the digital signal processing. It's designed to give the purest possible sound.
ok thanks (quick reply) would i still be ok to purchase a poa -t10..
Andrew Everard
1,878
Not sure whether there'd be any point, given that you're only running a 5.1 input from the BD player, with no way of processing out the extra channels for 7.1. It'd work with the Virgin input, however, as this is going through the digital signal processing.
If you wanted to use the extra amp and get 7.1, the solution would be to get a Blu-ray player with a 7.1-channel output, and use the Denon's lower set of analogue inputs, which gives 7.1-channel in.
the bd player does have 7.1 out have connected it for just 5.1 at moment /should i use the lower set of analoque inputs instead, bd is lg bd 390
thanks for quick replies...have been looking for a pair of energy encore 2 speakers to add to my others anyone know where i could could get some. great forum and magazine
