bigboss said:I think you mean 2000 lumens and not 200 lumens.
A 720p projector will always look worse than a 1080p one.
Lumens and contrast really depends on how bright your room is. If you can manage total darkness, even 900 lumens is sufficient. For bright rooms, anything over 1500 lumens is sufficient.
Which models are you thinking of?
abacus said:Don’t get obsessed with specs as bigger is not always better with projectors, (A properly designed 720p projector will look better than a poorly designed 1080p projector) so pop along to your local dealer and view some in your price range, as just like audio there is no one size fits all.
Hope this helps
Bill
Hope this helps
Bill
bigboss said:What's your budget?
This has a good review:
http://www.expertreviews.co.uk/projectors/1299286/benq-w1070
Personally, I wouldn't go for a 720p projector at all.
i looked for this a couple of weeks ago doesnt seem to be available anymore.bigboss said:Can you stretch your budget to this:
http://www.whathifi.com/review/epson-eh-tw5910
kikiso said:I recommend anyone to go and look at the DLP projectors first to see what they think.
kikiso said:I recommend anyone to go and look at the DLP projectors first to see what they think. I have an Optoma HD25 which in my opionnion does not suffer from any of the things mentioned. I woluld compare this to speakers, yolu can't go on specs alone, much depends on your environment and other factors. I'm projecting onto an 80 inch screen, and the room is darkenned, not always black and I find the picture very acceptable. Everyone who visits is amazed on how good it is.
I have never seen the rainbow effect, this effects some and not others, and as far as 3D is concerned, films are still being made in 3D and on a large screen they are great. I also have a 3D 50 inch TV and the 3D just doesn't have an impact and is a waste of time.
I'm not saying that DLP projectors are for everyone, but I want to just make the case for them as I'm 100% happy with the one I have. I am considering a better screen, I made a slight booboo with the pullup screen in that it ripples. This can be corrected by some messing about, but I'm looking to replace it with a fixed frame screen.
abacus said:Out of your two original projectors the decision is a no brainer, go for the 1070 as it blows the 750 out of the water.
I have always found DLP to have more definition, better blacks, contrast and a 3 dimensional quality, however LCD have come on in leaps and bounds in recent years, thus as you go up in price they are as good as (And better than many) DLP projectors.
You may be interested in Trusted reviews best buys here http://www.trustedreviews.com/best_projectors?Price%5B%5D=%C2%A3500+-+%C2%A31500
Just remember there is no substitute to actually seeing how they perform for you as everybody sees things differently.
Hope this helps
Bill
