http://www.dared.com.hk/index.php?route=product/product&path=92&product_id=168
Bought this as a band-aid to get me through as I needed a pre-amp to get my Quad 909 and Dynaudio X-12's going again. Cost me about 290 pound and about the size of 3-4 DVD cases stacked up, seems well built and is my first look into Chinese components. Just had the caps etc replaced on the Quad (Cost me 400 pound here in Australia!). Initially found the set up brighter than I would like, and quite different to what I could remember my system sounding like, but starting to grow on me as the system gets some run in time. I have been hooking up the Macbook to the USB Dac and using my Samsung S6 edge to control spotify. I can't say I have much to compare it to, I guess when I was using the Leema Pulse as the pre-amp I found the sound more pacy and fun but I have been without that set up for a good 6 months so not sure. I would say voices certianly jumped out at me from the start and not in a bad way. I have not tested as an integrated amp yet, only have the x-12's and B&W 685's, not sure if it will have the juice to get those going, but when I upgrade it may find itself in a small bedroom set up. Sorry its not a technical review but overall I am happy with it just to get me up and going again and makes me wonder what the more expensive Chinese gear can do.
