Dali Zensor 1 or Tannoy V1
Cypher
156
I have the Zensors...................I just want to know how good the Tannoys are............ :)
Sizzers
188
I’ve not heard either but I had the V1’s predecessor the F1 Customs, and although the Zensor’s are not exactly their replacement I have also owned the Lektor 1’s which I gather are not too dissimilar.
On that basis if I was buying blind then unquestionably I would choose the Dali’s so that is my answer to your question, although I appreciate it is not the same as an opinion born out of comparison.
Hope you don’t mind me going off-topic, but am I correct in saying that you now have the Pioneer A-30?
matthewpiano
494
332
19,270
Having owned both I'd say it isn't an easy choice and either would put in a great performance. The Tannoys have slightly more bass presence than the Dalis whilst the Dalis are a smidge more natural, but we're splitting hairs.
Cypher
156
My system ;
Pioneer N-30
Pioneer A-30
Dali Zensor 1
Thanks for the answers. I'll keep my Zensors for now :)
A Zensor 2 would be nice ;)
Sizzers
188
Apologies for going off-topic again but I’m very curious about the A-30.
There is zero info out there about it, so what is your opinion of it against the usual budget suspects?
Thanks.
Cypher
156
The Pioneer A-30 is a very nice amp. It has a almost analogue sound, very musical with lots of detail.
Build quality is excellent, it's built like a tank.
It had some great reviews in Germany ;
http://www.testberichte.de/p/pioneer-tests/a-30-testbericht.html
From all the budget amps I've had (rotel ra-04, marantz pm6003, nad c326bee) the A-30 is the best one IMO.
A true bargain, it costs 300 euro in Holland. For 300 euros you can't go wrong with this.
Cypher
156
I always thought the PM6003 wasn't that good at low volume. The A-30 is better in that department.........it sounds better at higher volume though but most amps do.
Listen for yourself.......music is such a personal thing.
Pioneer is also coming out with a A-50 amp and I would also audition the Onkyo A-9050 if you can.
ID.
207
AFAIK, this, like most amps, is analogue ;)
I think you'd normally use that description about a digital source (CD player, DAC, streamer...)
Sizzers
188
Well I totally disagree!
I thought the PM6003 was excellent for low volume listening - even with the on-paper “inefficient” Lektor 1’s amongst others - but I do agree that a good volume listening level is so much better!
Amongst other foibles my Arcam is terrible at low volumes – even with my Rothwell’s - but it does nicely comes alive after 9 o’clock but I’m really looking forward to hearing the Pioneer at some point.
Thanks for the input.
I just got the Tannoy's yesterday, I kinder wanted the Dali's but thought because they were shielded I would get Tannoy's, I later went onto find out it's only CRTs that need shielding, Oh well, still happy with Tannoys, can't comment on Zensors. . . they do cost twice as much though so I'd imagine them to be slightly better.
