DAB Pure One Radio Dead
JDF2012
13
Hi, my Pure One DAB Radio has suddenly stopped working.
If i press the Power Switch i get a popping noise like it is trying to switch on but nothing on the Channel Display. Its a 12v DC Pure Power Adapter.
Does anyone have any thoughts on what the cause might be? Could i try my Multi Power Adapter and see if that works?
Anyone know if this site is ok to by a replacement Power Adapter from?
Thanks 🙂
http://www.purespares.com/
Thanks 🙂
Not a clue, but the problem doesn't sound like a fault in the external mains adapter, or you'd get nothing at all when you pressed the power button, not even a 'popping sound'. Seems much more like a fault in the internal power section of the radio itself: ie the bit that takes the power from the mains adapter and distributes it to the various sections of the radio, such as the tuner, the amplifier, the display, ect.
