Hi all,
I currently have a Pioneer LX-83 paired with MK S150's and SS150 tri-pole surrounds.
In the usual persuit of audio visual perfection (read "upgrade-itis"), I am considering moving from the Pioneer to a seperate processor and amplifier set-up. This is mainly because, whilst the system sounds fantastic, the 4 ohm speakers which are rated up to 400W (LCR) can take a lot more power than the Pioneer can deliver, so I have always wondered if a more powerful amp will pay dividends in sound quality terms (dynamics, detail, control, soundstage extension etc).
Forgetting the 'processor' side for a moment; budget is an issue at present, so I am considering a few options.
I have only just started looking, so first off (option A), I have looked at the Rotel RMB-1575 paired with a matching RMB1572 to cover the 7 channels. I've not seen much else that offers the same sort of power for the money (though as I say, I have only just started looking).
Alternatively (option B) I could continue to use the LX-83 for running the surrounds, and as a processor, and add off board amps (mono blocks or 3 channel amp) to run the front LCR - this is new territory for me.
So my questions:
1. Does anyone have any experience of the Rotel amps above?
2. Does anyone have any alternative suggestions to the Rotel amps above?
3. What are opinions on option A versus option B?
4. Any suggestions for components to achieve option B?
As always, thanks in advance for any input.
So my questions:
