connecting Nintendo Wii to my AV receiver
shnicks
19
Hi there just got an LED TV and it doeasnt have the cables behind and i was wondering if it could be connected to the AV receiver. I assume i wouldnt get any video.
Any options as so how to coonect this?
thanks
Depends on your AV amp but you should be able to connect it via a component cable, if you hav'nt got the right one check here.
EDIT: Or check out Amazon, Play.com or UKHDMI for cheaper versions.
shnicks:
thanks
I have mine connected to my AVR via component and analogue audio and the signal is upconverted via hdmi to my screen.
