Dear all,
I know that people ask this question pretty often, but the situation is changing very fast. I would like to know the answer for the April 2015.
1. In your opinion, is it worth to use Tidal or Qobuz given that I use Macbook hooked via optical cable to Marantz 510 and Q2010i speakers? Currently I use Deezer with HQ. Will I hear difference? My room is not really optimal (about 70 sq. m.). How about good quality headphones either from Macbook or Marantz?
2. Will the answer to this question change if I will be streaming audio via Airplay? Is it possible to hear the difference between Tidal and Deezer in this context?
Thank you a lot!
Thank you a lot!
