- Aug 10, 2019
- 2,556
- 5
- 0
All my Sound and Video comes from a single HTPC, I built this to be small and really don't want to have a great big AV receiver, all the "standard" size ones seem massive to me which mainly seems to be due to the vast number of inputs and outputs, since I only need 1 input most of these seem redundant and simply a waste of space.
My current amplifier is an ancient QED A230S a great little amp in its day but in need of an upgrade, plus I want to get away from using the onboard DAC in my HTPC.
My requirements are pretty simple (I think)
1) at least 1xHDMI input for min Dolby 5.1 sound & 1080p video
2) at least 1xHDMI output to go to the TV
3) Ability to run as 2.1 channel (at the moment I only have 2 fronts & sub but plan to upgrade at some point in the future)
4) Budget circa £500
5) Most importantly this must be small, I really can't emphasize this enough - my current amp is 60mm High by 340mm wide and I really want something of a similar size.
6) Oh yes and ideally available in black.
I've looked all over and there doesn't seem to be anything to fit the bill.
Can anyone help? does such a device even exist?
