I'm planning to replace my ageing 2.1 PC speakers and one option is to reuse an old integrated amp I have lying around and get some small passive speakers, suitable for sitting on my desktop, either side of my monitor.
They will be for nearfield use only, and I'm not a basshead, so the (expected) modest bass will be fine.
I've been looking at the JBL Control 1, which get good reviews and are about the right size (not too deep, which is good!) but can anyone recommend some alternatives? For example, will something like the Q Acoustics 2010i be significantly better, given their larger size (and price)?
The other option is to buy some powered 2.0 speakers, e.g. the Creative T40, the Audioengine 2 or (and these are over-budget really) something like the B&W MM1 or the Ruark MR1.
Can anyone offer any comments / advice here? For example, the JBL Control 1 are approx the same price as the Creative T40, but I assume they would offer a significantly better sound?
Thanks!
Thanks!
