Clearer Audio Copperline power cables queries
Copperline power cable makes a distinct difference to both CD and amp. I was surprised how much if a difference these cables made. I'm guessing that you'll need the 320i IEC and UK standard plug but that depends where u are and what equipment you've got. Email Clearer Audio, they're very helpful
The effect will depend upon the existing quality of your mains. If you're lucky like me, your current supply is pretty good and therefore the most expensive leads will have little to no audible effect.
I'd suggest borrowing one first to see if you really can hear a difference, you might save yourself some money that could be better spent elsewhere..
I bought two of them and they does sound better. another audible effect is buying mains lead( tacima cs929) cheaper boost.
tq
Hi You're right i think i should borrow for audition first.
Hi thanks,
Alot for advising!
The next step will be my mains.... i think tacima is a cheaper invest... i should try this out first before the bolder step into the power cables
Clearer audio offer a 60 day money back guarantee, so you can try them out and if you notice no difference can send them back for a full refund!
