Chord Mojo 2
Johan Bottema
18,525
At the current standard of DAC from chinese manufacturing I believe that it is not justified to pay more than £300 for a DAC. A DAC of £500 should be at least 32bit 384Khz, 256DSD and should have USB-C, Optical, SPDIF, XLR balance out, High current headphone output, volume knob and a remote control ... and it should have 20-21bit linearity, proper filtering, S/N >125dB ... And I am not falling for the whole brand name thingie considering all these DAC's use the same chipsets; and for that matter some of them fail on the filtering part. I don't think I will be buying this Chord DAC unless it drops well below £200 and then only because it looks funny with the colored LEDs.
ALW
Of course the Chord doesn't use the same chipsets as any other non Chord DAC and that is where the potential value comes.
I have a Mojo and a Topping DX3 Pro+. On paper the latter is better, based on standard measures, but in terms of sound the Mojo is far ahead in my experience.
The Topping is great for the money and I bought it for it's flexibility, primarily, but the Chord just presents music more cohesively, while the Topping dissects it.
I buy kit like this to listen to and enjoy music and I rate the Mojo as the best piece of HiFi I've bought in decades, in both sound and value for money.
Reactions: doifeellucky
doifeellucky
This is some subjective feedback based on actual use. I bought one and I’ve been testing it for over a week. For me, in terms of absolute sound quality, it is arguably no better than a cheap dongle and I’ll be returning it due to a specific issue which I’ll come to.
I tested with hi res and tidal hifi on Mac, PC, iPhone and Pixel. I’m only using Grado 325x, which I’m sure some will say are not good enough for this level of product, but regardless of that there should at least be some improvement over something costing less than £10. For me there isn’t. I’ve repeatedly listened to high res live classical performances, and all the fine detail can be heard without the Mojo 2. Every genre I’ve tested sounds the same to me. I’d be disappointed if I’d spent £100 and got no benefit, let alone £450. The lowest DSP setting isn’t audible to me, which another reviewer with Arya Stealth also noted, and crossfeed does nothing worth commenting on.
To make matters worse when connected to my phone via usb c it even makes an audible click every 5 or so seconds. I checked on a forum and for the original Mojo the fix for ‘interference’ is to put your phone in airplane mode, making it utterly useless as a streaming playback device. I’m returning it on that basis.
I’ve seen other comments from owners, or those who have demoed it, saying this sounds no better than a Zen DAC V2 or something price equivalent, which I completely agree with.
Part of the reason I spent this amount was to also use it in my system to replace the inbuilt DAC in my Cambridge amp. I bought the suggested 3.5mm to RCA cable and again no noticeable difference.
The mojo 2 is an over hyped product, in my opinion of course. This is just a warning to those expecting some sort of ethereal experience with this product. Perhaps if you spend £1500 on some headphones you might get it, but I’d imagine a fairly high proportion probably won’t.
On a side note The cheapaudioman once said he typically only ever uses an Apple dongle when out of the house because it’s more than good enough. I’d tend to agree.
Mr. Reeee
10
Does anyone know if you can control the volume of mojo 2 from computer when on usb? Previous mojo had volume control only from the buttons.
Yes!
I recently picked up a Mojo 2 to connect to my MacBook Pro and drive a pair of Grado RS1x headphones.
So, yes, you can control the volume from a computer. The Mojo 2 is sitting behind my keyboard, so it’s easy enough to adjust volume with it.
Jan 12, 2023
For what it's worth, my subjective feedback on "actual use" is that the What Hifi review is spot on and the Mojo 2 sounds amazing. Better than any DAP costing significantly more money. It's interesting that doifeellucky can't hear any improvement over a "cheap dongle" in stark contrast to What Hifi and all the other five-star reviews, which are dismissed as hype. I've not seen or heard of any "comments from owners" who feel let down by the Mojo 2. In fact, quite the opposite and you can easily find on-line forums from owners that state how good it is. I'd expect the "DAC in a Cambridge amp" to already be pretty good although, of course, such an amp won't be portable. While the Mojo 2 doesn't claim to offer an "ethereal experience", it does significantly improve the enjoyment of whatever music you listen to. For me that's been well worth the cost and I listen to the Mojo 2 everyday - but of course it's always a good idea to listen first before you 'splash the cash' as they say and most hifi dealers will let you try before you buy.
gitesh_b
18
Not an issue based on the reviews I’ve seen. One specifically connected it into a Hegel 390 with 3.5mm to RCA and said it worked well.
I recently brought B & W 706 s2 speakers but I find them bright for listening to streaming music on my stereo setup comprising of harman kardon 3380 stereo receiver , speakers and iPad . They are causing me ear fatigue though rest of the family is fine !!
I use my iPad directly connected to my Harman kardon 3380 stereo receiver to run the speakers . On the iPad I stream Amazon music .
I was thinking about some solution for brightness and I read about mojo 2 . My question is that can I use Mojo 2 equaliser connected to my iPad for reducing the brightness in my stereo set up .
