Chord Company SuperScreen or Russ Andrews Reference PowerKord W350i Ag
Passion
Hi, I had a question about those powerkords im concidering to update later again my system... But does it really make a diiference... and what is the big diff about those 2 cables, what should you recomment me? System details:Cyrus 6XP Cambridge audio DacMagic 100Van den Hul Analogcable The NameVan Den Hul Clearwater speak.cable/100Monster Power HDP 650 PowercenterSpeakers: B&W CM5HP Envy m6 laptop
If you do a search on WHF forums you will find many threads on this subject.
However if you decide to go for them make sure buy them on a return basis, as once you have tried them using a blind test, you will find there will be no difference in sound or quality to the manufactures standard cord.
Hope this helps
Bill
Hi Passion, and welcome to the forum.
I agree with Abacus in the sense that you should try this for yourself, with the ability to return; however I disagree that they never have an effect (which is usually, though not always, for the better).
Of the two you listed, I would rather go with the RA, but would also throw in Clearer Audio (give Darren a ring)....I believe both RA and CA have a 60 day return policy.
I have found that they make more difference on amps, while others have found that it is the source that benefits most. Suck it and see....then let us know what you have found.
Cno
ok thx, It hard to get some of those powercords, cause im from the netherlands, well I noticed I used A cheap powerlink, and now I m using since yesterday Monsterpower HDP 650 powercenter, well I must say the answer is yes! you hear clearly the difference more bright before and clear volt offcourse🙂 but dont connect to many on it I only connected my DAC and my Receiver on it! Offcourse you need a good system to hear to difference otherwise it has no use....
As I said, give Darren of CA a ring if you want to try something.......if he can possibly help, he will:
http://www.cleareraudio.com/index.php?main_page=index&cPath=1
