CD or DVD?
hi folks,
I'm a rookie, so go easy...
I'm updating my out-dated system and need some advice. Firstly the CD player.
I want a budget player to handle CDs and compilation MP3 discs
I'm thinking of something like the NAD C515 or Harmon Kardon 980.
But then I thought, a DVD player will also do this - should I be more modern in my thinking and be buying a DVD player instead?
Will I get similar sound for similar money, but more longevity and flexibility? or not?
mark
An old chestnut perhaps...
Well, a seperate CD player will in most cases sound better, but since your suggesting Harman Kardon i would opt for the HD990 instead of the 980 becausse the 990 can be used as a standalone DAC to if you wish to play for example music files stored on a HDD with good quality.
http://whathifi.com/Review/Cambridge-Audio-Azur-650BD/
Does the lot.
Or wait for Panasonic's new range of BluRay/DVD/HDD/FreeviewHD recorders due to hit your shops soon. (You effectively get every format and Freeview radio/FreeviewHD telly and an internal HDD to record onto and iPlayer etc etc.)
If you are not bothered about BluRay or HD then £290 will get you a Panasonic DMR-EX83 (with standard Freeview and built in HDD etc)
Plug the digital audio (optical) output into a decent £250 DAC like a DacMagic or Beresford Caiman (or Musical Fidelity V-Dac for £150) and I doubt you will notice much difference with any dedicated CD player under £500.
RCduck7:Well, a seperate CD player will in most cases sound better, but since your suggesting Harman Kardon i would opt for the HD990 instead of the 980 becausse the 990 can be used as a standalone DAC to if you wish to play for example music files stored on a HDD with good quality.
I'll second this. I've never found a DVD player to match the audio quality of a good, dedicated CD player, even if it's only used to send out a digital signal. Even in an AV system, the CD player will usually win through.
