- Nov 5, 2012
- 2
- 0
- 0
Hi all,
I ordered some rca an xlr plugs yesterday to cover unused outputs in my system. I have a pair of unused, non-switchable XLR outputs on my DAC (Antelope Audio Zodiac) and two pair of unused, non-switchable RCA outputs on my preamp (The Gryphon BelCanto) one pair analog out and one pair d-out.
My reasoning is as follows: if these outputs are in parralel to the used outputs, any static that is picked up is going through the signal. (Don't know if this is correct, can anyone confirm this?) So capping unused outputs should hopefully improve signal to noise ratio.
I plan to test it by:
1 listening to the amount of static on high volume without signal before and after
2 "measuring" to the amount of static on high volume without signal before and after with a phone-app
3 normal listening test with music before and after
The caps should arrive later this week, possibly early next week. In the meantime any input/correction on my theory and proposed tests is appreciated.
