Cantilever Stand for Panny 37PX80B. Will it fit?
Hi, I have decided to get the Panasonic TH-37PX80B TV and I have been looking at stands for it and my AV equipment.
I like the Jual JF009 here: http://www.standanddeliver.com/acata...09-SILVER.html
The screen will therefore be mounted to the stand, as though it was on the wall.
But I have had a look at the back of the TV in the shop and through the instruction manual and I cannot see how it could be mounted.
The Instruction book mentions several wall mount brackets but they seem to relate to the 42" version and I am not putting it on the wall.
I have a smaller 22" TV and that has standard VESA 100 mounting holes on the back so I was looking for something like that?
Can I do this?
Are there mounting holes on the back of the TV that I have not noticed?
I have the 37PX80, I haven't wall-mounted it but I believe the mounting holes are concealed behind 4 little black discs. Have another look at the back of one and you should see 'em.
I can confirm this as I have a 37PX80 wall mounted in my living room!
Lewis is right - the holes for bolts are behind four black plastic discs on the rear of the set.
Thanks very much for the replies.
I had seen the discs on the back of the TV theyre about 1" to 1.5" in diameter and I hoped thats what would be hiding behind them.
I will be ordering my new TV and stand tomorow.
