Cant find suitable Stand For AV/Receiver
I have looked everywhere trying to find a stand for my plasma, av receiver and centre speaker. The problem is i cant seem to find anything with the depth i need (400mm with open back for bannana clips) i also need the bottom shelf to be 200mm in heght and the middle shelf 171mm.
It will need to look ok to get it past the wife as she thinks most look like a rack????
Not a specialist site, but give www.mydeco.com a try maybe. You can specify the required dimensions (though not for internal shelves unfortunately).
mark8par:
hifiracks.co.uk - you design it how you want it. I know there are others as well as Joelsim and me that have one of these.
