TrevC said:
rmatthew said:
My speakers are bi-wired so I currently have my speaker wire unterminated and fed through both connectors. I've read some very favourable reviews of the Tellurium Q Black but as they are flat I was wondering whether it was possible to cut them and connect to the speakers untermined. This would also have a cost benefit as I only need about 0.5m on one side and 2.5m the other so I could buy a 3m length and cut accordingly.
Thanks.
Why not just buy proper cable like this?
http://tinyurl.com/j8xgbe9
It's 6mm, so there can't be any losses for your lengths.
Copper Clad ... ?
Perhaps copper plated alu or steel?
Insulation material? I would guess its PVC, cheap n'cheerful and not to clever as a dielectric.
Stranded ... I'd go solid core but I have used good quality stranded cable (including the one used at present)
Parallel configuration ... You may receive BBC radio ...
Just a few thoughts.
Other than that, its a great cable
