CAN I USE AN OLD 110V-220V MAINS AMPLIFIER MADE FOR THE GERMAN MARKET IN THE UK ?
ZTEK65ZAP
Hi Everyone
I would like to know if I can use an old Receiver (Tuner/Amp) from the late 70s rated at 110-220V 50/60hz made for the German market in the UK ?
From what I'm aware we in the UK use 230V with a tolerance -/+ range of 216V to 253V. Germany uses 230V (I don't know about their tolerance -/+ ranges)
I'm probably being over cautious here as I'm guessing it should work ok but I just want to make sure before plugging in such a high power unit taking into conisderation of it's power supply specifications of input mains voltage.
Could someone please clarify ?
Yes, Please make sure the voltage switch is set on 220V. If you fail to select it to the correct voltage, it will be like the 5th of November inside your house.
Yes, good advice, mind you I suspect that electrical goods "manufactured for the German market" will have fuses to prevent the "fireworks" you so eloquently describe..... 😉
