A admin_exported New member Aug 10, 2019 2,556 5 0 Sep 21, 2009 #1 Hi there - my Denon 4308A has wireless connectivity so is there a way I can have it running on my PC but playing through the Denon? Any help much appreciated. Thanks, Ed
John Duncan Well-known member Jan 8, 2008 2,035 32 19,720 Sep 21, 2009 #2 Not directly, unless you can find a UPnP server that will convert to WAV on the fly - I found one recently that claimed to, will dig it out. Otherwise, Aiport Express and Airfoil is the way to go...
A Anonymous Guest Sep 21, 2009 #3 I think you might mean this one http://www.sdstechnologies.com/Default.aspx Discussed on this thread http://community.whathifi.com/forums/t/304205.aspx I got it working on my Yamaha RX-V3900 and am mighty chuffed with myself!
John Duncan Well-known member Jan 8, 2008 2,035 32 19,720 Sep 21, 2009 #4 Yeah I couldn't immediately find the thread, or remember which uPnP server I recommended in the first place
A Anonymous Guest Sep 22, 2009 #5 Thanks for the replies. I will check out the other thread and revert. Thanks again.
