camcroft said:
The cartridge is a Ortofon 2 red and the cable from the Project turntable to my Rega mini phono stage is a Qed Quinex 2 and on the other side is a Atlas integra element to the reciever/amp
Hi camcroft, cables in my humble opinion are a soft option and from what I read on forums lead to going round and round and . . . you can spend a fortune and eventualy disapear down the hole in the center of the record! . . . cleaned that one up
I think Chebby has a point with improving the cartridge, big improvements here, depending on budget. I have spent the past 2 years upgrading the front end of my system, it did not cost me a fortune but required patience, time and personal honesty at each change or adjustment, 'better, worse, no different or a sidways move'? Takes time and understanding, understanding comes with the time.
I got to a point where the front end signal was obviously so good, it was time to look at the rest of the system, to make the best of the SQ and effort put in over the two years. The thinking is, why bother to fiddle and faff with cables, amps, speakers if the origin of the signal is not up to standard. This is not a new idea, goes back to the early days of Linn; "rubbish in, rubbish out" . . . if infomation is lost at the point of source, you cant add it later.
CJSF
PS something I found that has been a tremendouse help, the use of a digital stylus scales, around £25 on fleaBay. I new that stylus presure changed the sound a suprising amount, but the Rega arm markings were wowfully inacurate I discovered. Now I can repeat a downforce to within 1/100 of a gram every time! Dont sound like much I know, but it was a big step forward for me, accuracy and repeatability is everything I found.
These are the scales I use: 200796934351 . . . but these are the latest version: 350322574886
