BR Player Multi Zone advice
EvoKazz
24
Hiya guys, I currently use a Panasonic BD220 BR Player and love it, it's a mid range priced one, so nothing majorly flash, but got really good reviews and I cannot fault it. I recently got the Blu Ray bug, and realised a lot of the movies I want are USA only, most are UK, but some I really want are USA, on checking a fair few of them are region locked :-(
So I am looking into a new BR Player, I don't want to pick up one of those cheap ones with a multi hack, I still want a really good BR Player, but with Multizone functionality. Here's my requirements:
Budget - £300
Brand - Would like a Panasonic again
Region - Play ALL DVD'S and ALL BluRays
Quality - Mid range player, not looking for a massive high end system
Some questions: Will these Multizone mods make the player die quicker? Also where do people buy them in the UK? (Link would be awesome).
Check this if you want something cheaper:
http://www.tps.uk.com/?tab_name=Panasonic&tab_id=52&choice_name=Blu-ray_Players&choice_id=143&product_group_id=224&product_name=Panasonic_DMP-BDT260EB_MULTIREGION_Smart_3D_Blu-ray_Player&product_id=2065&choice_type=1
