- Aug 10, 2019
- 2,556
- 5
- 0
First post on here and I know I'm setting myself up for some stick admitting that I've bought some Bose gear......
I have recently bought five BOSE Cube speakers, they are double speakers and I think that they are "Lifestyle" ones. At the back of the speaker housing they have a button that pushes in to connect the cables.
(1) The cubes didnt come with a Sub and I know I need one. If I stick to BOSE, is it only the "Lifestyle" series of Sub that I should be looking at? Does it matter what "Series" etc? I've seen some of the Subs are "powered" and some of the earlier ones are not, what should I go for?Do I "have" to go with a BOSE Sub or could I theoretically go with a KEF or similar unit?
(2) My idea is to run the audio of my TV and connect my SONY seperates system through these. I guess I will need an AV Receiver to do this and although I'm not the expert, I dont think that I "have" to have a BOSE one? If I didnt go for BOSE any suggestions of which one I should go for? I've looked at Richer Sounds and there are a few around the £200 level, a couple of SONYS, YAMAHAS and ONKYO, any suggestions? Should I be looking for some specific, or trying to avoid something?
(3) The system is going into a new extension which was recently built. I installed cables in the wall and they are ordinary good quality HiFi cables not BOSE. The cubes that I have bought look as if they can take a "bare" wire but what about the other end? Do they go into the AV Receiver or the Sub? Will I need to get phono plugs on the ends or does the Sub / Av Reciever take a bare wire?
(4) I have a feeling that if I use a BOSE Sub, that the cubes connect to it directly. If that is so, assuming I dont use a BOSE AV Receiver, what do I use to connect the Sub/Cubes to the Receiver? What kind of cable?
I know there are a few questions, so my apologies and thanks in advance.
David
David
